Re: run Farmall 6V w/a 12 battery??
Posted by John T on October 25, 2005 at 16:23:38 from (66.244.90.98):
In Reply to: run Farmall 6V w/a 12 battery?? posted by PL on October 25, 2005 at 15:58:11:
PL, if you run it at 12 volts and it still has only a 6 volt coil AND NO ADDED EXTERNAL BALLAST RESISTOR ???? (if it has a coil ignition instead of a magneto which requires no changes as its not battery connected) the coil will run hot plus the ignition points will burn up prematurely. When converting from 6 volt to 12 and still using the original 6 volt coil, one must add an external series voltage dropping (12 to 6) power ballast resistor (rated around 1.5 to 1.85 ohms or so) after the ignition switch and ahead of the coil to prevent coil overheating and premature burning of the points. Or else just replace it with a full 12 volt rated coil. True, a 6 volt gen wont keep her charged. I have used 6 volt gennys to charge a 12 volt battery by simply changing the 3 or 4 terminal Voltage Regulator (if it has one versus only a 2 wire Cutout Relay) to a 12 volt BUT AM NOT SAYING thats the correct or engineering proper way to do it, only that it worked. Its best to have a good genny shop convert it to 12 volts and use a 12 volt 3 or 4 terminal VR or one can still use the old 2 wire cutout relay system by replacing the Cutout Relay with a 12 volt unit. Any working lights need, of course, to be changed to 12 volts. The starter will work on 12 volts, although it may possibly be a tad rough on starter drives or flywheel teeth due the the higher kick in torque. John T Nordhoff in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
