Releif Valve Setting?
Posted by Mel in OR on October 26, 2005 at 14:38:47 from (67.164.106.40):
Thanks much for all your help in the past. On my 1946 Farmall M with converted hydraulics (Dad added a distributor pump and cover plate - from a Super M or 450 I think), what maximum pressure should a releif valve be set at? I just replaced the cam gear and don't want to have to go through that again. I am having my cylindar and valve tested. I suspect the valve releif did not function which caused the gear to break. I assume the new gear is stronger and will handle more than 800 psi (for a Lift All), but what would you recommend?
Post a Followup
