Re: New PTO seal ???
Posted by MN Scott on October 26, 2005 at 20:25:30 from (206.9.216.27):
In Reply to: Re: New PTO seal ??? posted by AC Hodges on October 26, 2005 at 20:04:45:
It would be a good idea to pack a little grease between the two seals so the outer seal has lubrication or it will rapidlly wear out. Acually two seals are not really needed as the new seals have much better wear and sealing power than the old leather type. Most equipment since the 60's has had the narrow type seals and they for the most part have stood up well to time and use.
Post a Followup
