Re: 504 gas
Posted by El Toro on October 27, 2005 at 04:12:21 from (152.163.101.13):
In Reply to: Re: 504 gas posted by ps on October 26, 2005 at 18:39:13:
You could probably just put a set of new rings in it if there's no grooves worn into the cylinder walls. You may have a broken ring and you will need a ridge reamer to cut away the ridge so you don't damage the pistons. The best way to check for wear is to measure the cylinders. You should have a shop manual that covers that 153 engine. The ring gap on a new ring will also determine if the cylinders are worn too much. My IH manual doesn't cover the 504, but it does list the ring gap for Farmall H with the C152 engine and the ring gap should be .007" to .017" on a new ring. You need close bearing clearances too and that includes cam bearings for good oil pressure. New gears in the oil pump if worn severely too. I do have a sketch of that oil pump listing the parts. If you're in doubt about the wear have someone measure the cylinders. You may need new piston pins and bushings since they can cause noise with new rings. Valve guides need to be checked for wear too. Hal
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
