Farmall Tractors Discussion Board
Re: Touch Control Fluid ?
Posted by Phil Auten on December 28, 1999 at 19:51:57 from (206.175.72.226):
In Reply to: Touch Control Fluid ? posted by Stan on December 28, 1999 at 19:02:58:
Stan,
I would use IH Hytran to replace the touch control fluid. That is Hytran's intended use, a hydraulic fluid. As for what to watch out for, the only thing that immediately comes to mind is to look carefully at the old oil for signs of wear like metal particles and such. Be sure that the rams are in the collapsed position so all the old oil is in the reservior before draining.
Good luck,
Phil
Post A Followup
: Re: Re: Touch Control Fluid ?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
