Re: Cub hyd leak
Posted by George Willer on October 28, 2005 at 13:54:07 from (208.252.179.24):
In Reply to: Cub hyd leak posted by Florida Tom on October 28, 2005 at 11:11:07:
Tom,
The four bolts merely hold the unit to the tractor, and have nothing to do with pressure on the gasket. It's possible, but not real likely that you can remove those four bolts and raise the unit high enough to get at the bolts holding the bottom cover on to tighten them.
Maybe it's time to just remove the unit and overhaul it with new O-rings , gaskets, and screen? If you do decide to do so order the kit according to the part number on the casting. There are two different kits... and they don't interchange.
George Willer
Post a Followup
