Re: stuck C
Posted by Herb in Texas on October 29, 2005 at 19:40:49 from (69.60.180.84):
In Reply to: stuck C posted by Ben Rauls on October 29, 2005 at 16:50:57:
I aggre with the stuck starter and needle valve opinion But I wouldn't loosen the starter and try to crank it. That could be a real problem should the starter gears bind. The drive end could be completely destroyed. (don't ask) simply loosen the starter bolts several turns past where the lock washers relax the get ahold of the end and shake the livin tar out of it you should feel the hung gear release. the run the bolts up tight and crank. Then go to TSC and get a overhoul kit and fix the carb.
Back in fine shape in under 2 hours. Not counting the drive to town.
Herb
Post a Followup
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
