Re: Cub headlight switch ?
Posted by George Wallace on October 29, 2005 at 21:26:35 from (66.168.159.111):
In Reply to: Cub headlight switch ? posted by Andy Engel on October 29, 2005 at 14:30:54:
If you have a cutout switch instead of a voltage regulator that resistor does more than dim the lights. If you look at your amp meter while the tractor is running you will see that the tractor is charging at a high rate. If you plow all day like this, you will over charge the battery. To cure this, you use the light switch to regulate the current going to the battery. On my cub, the amp meter is at zero with the lights on bright. The dim setting allows some charging but will not over charge the battery. Now, since I do not have any experience with a cub with a voltage regulator, I do not know if this still holds true. See the attached link for a pretty good cub wiring diagram.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
