Re: H Motor Stuck
Posted by John A. on October 30, 2005 at 16:21:30 from (65.161.170.79):
In Reply to: H Motor Stuck posted by Tweeter on October 30, 2005 at 14:55:26:
Tweeter, First remove the gas tank, roll the tractor out of the shop. Keep all flamable liquids away!. Now one at a time pour diesel into the cylinders and set fire to the diesel. Let it burn itself out....Then drive out the piston. The heat from the fire will break the rust, expand the cylinder from the piston,and make it more easy to get apart. You will still be able to reuse the parts unless there are toooo much rust pits. or unless the rings are rusted up solid. The acetylene will heat it all up but be careful not to melt the metal if you plan to reuse the pistons and cylinders. Hope this helps.
Later,
John A.
Post a Followup
