Re: For Magman clutch
Posted by Janicholson on October 30, 2005 at 16:27:23 from (66.173.50.34):
In Reply to: Re: For Magman clutch posted by MagMan on October 30, 2005 at 11:39:28:
I'm He.
LPS is a brand name of several products. I have used many of them and found no complaints. The corrosion inhibitor product is a spray can packaged liquid which goes on rather wet then dries to a very thin coating. the coating repells water and other chemicals, but is easily burned off with running the engine. As I said ive used it on several engines including one that was not run or turned for 10 years. I also use it on firearms for long term storage, inside and out (except on the wood). one could fire the gun through the film, but it is best to use one swab of hoppies #9 to clean the bore.
LPS is usually found at autoparts stores, NAPA has had it as well as many others. Hardware stores also carry it especially those serving a broad customer base not just suburbanites.
Good luck, my Email is open.
JimN
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
