Re: M Cam Shaft
Posted by smp on October 31, 2005 at 10:21:22 from (64.184.7.16):
In Reply to: Re: M Cam Shaft posted by El Toro on October 30, 2005 at 18:13:56:
You can still get brand new 450 cams, that would wake up the old M a bit also, they have left handed threads so if you put on live pump the nut isn't going to come off.
Post a Followup
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
