Re: M Pinion shaft seal
Posted by Haas on November 01, 2005 at 06:36:52 from (12.65.30.124):
In Reply to: M Pinion shaft seal posted by biggerred on October 31, 2005 at 17:51:36:
Yes you can replace the seal. However do not try to remove the bearing cage. You must first take the bull gear off the axle before you can remove the bearing cage. The seal runs on the brake drum, so when you remove the drum, there is a space between the pinion shaft and the seal. I used a puller with the jaws turned out to get the old seal out. It will come out in pieces, but with some help from pry bars, etc, it's not too difficult to get it out. Make sure you also get a new seal (gasket washer) that goes under the retainer washer for the brake drum. If you don't have that, oil will leak around the splines of the pinion shaft.
Post a Followup
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
