Re: H locked up in 2nd gear
Posted by Jay (ND) on November 01, 2005 at 12:38:33 from (66.231.118.95):
In Reply to: H locked up in 2nd gear posted by jim in columbus on November 01, 2005 at 11:21:49:
I'm not even close to the most qualified to answer this, but until someone else comes along, it appears that I am all you have.
No, you don't have to take off the main deck. What you have to do is follow the gear shift down to the tube coming up from the deck. On the sides of that tube, there may or may not be welch plugs. If there is, remove them. If not, you will see approx. a 5/8" hole. In that hole is a pin. Push that pin out one side or the other. You may have to push down on the gearshifter a bit to relieve some pressure. Now the gearshifter should just lift straight out.
In that hole, you will see the rails. 2nd gear is on the 2nd one from the left. If I remember correctly, you have to put the shift lever forward to get to 2nd gear - that would push the spoon of the shifter backwards. So your second rail is stuck rearward. Get a screwdriver and push it forward. You may have to rock the tires a bit while doing this. Now you can put it all back together in reverse order, however, I would take the spoon on the bottom of the shifter and build it up with weld and grind it down to the right size. That should keep it from happening again for a long time.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
