Re: seal replacement on H
Posted by Loyd in Texas on November 02, 2005 at 13:01:26 from (67.77.73.111):
In Reply to: seal replacement on H posted by KWR1973 on November 02, 2005 at 12:08:41:
Yes, it can be done. First drain front and rear of the case. Next drop the lift-all unit. This will give room to get to the drive shaft. Next tie the clutch pedal down to keep clutch engaged. Next remove the four tapered bolts holding the drive shaft to the transmission driving shaft bearing cage. Slide the drive shaft toward the clutch as far as possible. Next remove the transmission drive shaft coupler. (This can be hard to do, but easier while attached to the tractor.) I use a gear puller and a washer that keeps the puller from messing the female thread up. Next remove the three 3/8 inch bolts holding the seal and pull. I would replace the countershaft seal at the same time. (Where the lift-all conected.) If necessary the whole drive assembly will drop out with some juggling. This will require the gaskets be replaced however or new ones made. The PTO can be done without pulling the shaft. Just two cap screws and the seal cage comes off, unless it is one of the really old one's. Good luck, Loyd
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
