Re: Broke PTO shaft on 966
Posted by the tractor vet on November 02, 2005 at 14:41:50 from (4.124.70.24):
In Reply to: Broke PTO shaft on 966 posted by RJ in NE on November 02, 2005 at 14:06:53:
Well not a real big deal other then ya have to comp;etly tare it apart THe big thing is not to bang -damage the pickup tube when ya pull it out . The best way is to use a cherry picker and a short chain about two to two and a half feet long and attach it to one of the top bolts near the center and use a long pointed punch to tip the nose up as you come out , then ya need to make up a couple special tools one as a spring compressor and the other to go over the shaft to press the plate and spring down a pice of 2 1/2 inch pipe about 6 inches long and weld a cap on it then cut about a third od the open end out so you have access for the snap ring pliers and snap ring as for the spring compressor a flat pice of plate that is 8 inches long and three inches wide and atleast half inch thick. and ya need two pices of 3/8th all thread 13 inches long and four nuts and a couple flat washer . The demenshoins on the pipe are as i just checked mine are six inches long by 2 1/2 and the slot is cut up into the pipe 2 /34 of and inch and like i said cut out about a third of the pipe now you have the main tools to pull it apart along with a real good snap ring pliers and i do mean good one keep in mind that that spring can take your head off. And while your in there ya just migh as well replace the clutch pack and install the hd. one then the other thing ya need is the special fitting to set the pressure , this is a special fitting that can only be had from case i h so here is the way ya get it go to your friendly Case I H parts dept and tell the guy that you need this here part # it is 384328R1 oriface but don't tell him what it is just tell him that it is a fitting that you need . then ya have to make up a hose and fittings with a good gauges that will handel 600 lbs. pressure . And a IT manual will also help. your to far away for me to fixit for ya as it only takes me about three hours from draining the tractor to setting the pressure . Did like six of them one year back to back .
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
