Re: Dead solid miss in 350D
Posted by P Backus on November 02, 2005 at 19:11:50 from (69.128.32.195):
In Reply to: Dead solid miss in 350D posted by Bleed IH Red on November 02, 2005 at 17:34:41:
I think Scott is onto it.
When you crank the engine over, does it crank evenly, or does it
have a lope to it? Many times you can tell if there is a
compression problem by listening to it crank (if it doesn"t start
right away). Sometimes you can hear where the compression is
going too, ie out the exhaust or out the intake/air cleaner.
Paul
Post a Followup
