Re: AW d-9 engine rebuild kits ??? 1955 model i th
Posted by El Toro on November 04, 2005 at 10:32:14 from (64.12.117.13):
In Reply to: AW d-9 engine rebuild kits ??? 1955 model i thunks posted by Twinfire 77 on November 04, 2005 at 01:14:40:
The SN should be on the left side of clutch housing or transmission housing. The WD9's were made to 1953. Click on Serial Numbers to your left under Research & Info. Look under McCormick-Deering. Hal
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
