Re: Farmall A and B lights.
Posted by Paul in Mich on November 04, 2005 at 16:44:34 from (64.12.117.13):
In Reply to: Re: Farmall A and B lights. posted by Dave H (MI) on November 04, 2005 at 12:35:57:
Dave, The "B" and "BN" were not produced beyond 1947 so were never equipped with flat back sealed beam lights. The lights were the tear drop with replaceable bulbs. The only difference from the ones on the "B" and the "H" and "M" was the length of the mounting bolts which were shorter on the "B" or offset tractor models. This is due to the fact that there was not a compression clamp to require the added length as in the "H" and "M" versions. The longer bolt versions, however will work just fine on the short bolt applications.
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
