Re: Water good , in oil -bad ! ( long )
Posted by RAW in IA on November 04, 2005 at 16:46:36 from (12.214.222.143):
In Reply to: Water good , in oil -bad ! ( long ) posted by Randy-IA on November 04, 2005 at 16:30:43:
If it has beensitting outside a lot, water in the transmission is normal. Comes in around the gearshift liver I think. Some will get so bad if not drained regularly that theywill freeze up and not move in the winter. Need to loosen the drainplug once in a while to drain off the water after it has sat a while. My cub did the same thing. Was real noisy till I changed the oil, but it only holds about a quart!
Post a Followup
