Re: Farmall A and B lights.
Posted by Jim Becker on November 04, 2005 at 17:21:53 from (71.96.33.51):
In Reply to: Farmall A and B lights. posted by Dave H (MI) on November 04, 2005 at 10:27:58:
I think you have the right answers scattered through these replies. But to try to put it in one place and add a little bit more:
- The same teardrop headlights were used on all Farmalls when the B was made.
- The carriage bolt in the bottom of the lights were all the same length but 2 different lengths of tubing were slid on the bolt. A and B used the long tubing for all three lights.
- Headlight posts on both side of the B were the same as the long (left) one on an A. The rear light used a short post. The rear post was to be shortened even more for some mounted equipment. The AV used different posts.
- When the pneumatic lift cylinder was mounted by the radiator, the left post wasn't used and the bracket in your picture was used.
- When the tractor was equipped with a single front light, it was on the right with the left wire taped back in a loop.
Post a Followup
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
