Re: 685 brake problems
Posted by Bernard le mécano on November 05, 2005 at 06:08:50 from (207.134.201.189):
In Reply to: 685 brake problems posted by MNredfarmer on November 04, 2005 at 17:13:56:
Hi MN, try to bleed the brake system,stop the tractor for 1 or 2 days and check one pedal at the time to see wich is the side in trouble. Unlock the pedal to make the test, because, if you press both pedal, it have an equaliser valve in the system. The pedal that goes down have a leak in the piston.
Bernard le mécano Québec Canada
Post a Followup
