Re: Multimeter use help
Posted by John T on November 05, 2005 at 09:14:30 from (66.244.90.98):
In Reply to: Multimeter use help posted by Granger on November 04, 2005 at 23:46:15:
Granger,
1) If you dont know what voltage youre gonna encounter, start with the meter being set on the higher voltage ranges then work your way down.
2) Many have Red + leads and Black -, so hook then up to DC accordingly, or they peg the meter bass ackwards.
3) The meter should have scales for DC volts and AC volts and ohms, so set if for what youre gonna encounter, again starting at higher then expected n work your way down.
4) If you wanna measure resistance/continuity, set it on the ohms scales and dont hook the leads to anything that has voltage running to it.
5) Most tractor troubleshooting is for DC in the 6 and 12 volt ranges, so set the meter in the 25 or 50 volts etc ranges for proper needle deflection when measuring voltages.
If all else fails, break down n read the directions I reckon, lol
John T, retired electrical engineer in Indiana
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
