Re: 656 spark plugs fouling
Posted by John T on November 05, 2005 at 19:03:56 from (66.244.90.98):
In Reply to: 656 spark plugs fouling posted by goterdone on November 05, 2005 at 14:04:23:
When you remove them after fouling do they have a flat black colored but even sooty look, (excess unburned gas) or a shinier wetter uneven look (oil burning). Does she throw much blue smoke out the stack under a load?? thats more of oil burning, but if she throws excess black smoke thats more like excess gas from runnin too rich. If its excess gas (black smoke), try leaning the carb and insure the chokes opening n staying open and that the air cleaners not clogged up. If its burning oil (blue smoke), maybe run heavier oil like 20W 50 n see if it helps any. Things that can extend plug life for oil burners or excess gas are to use shutters or thermostats or air flow restrictors on the radiator to get n keep the operating temp up to 180 and over. Of course, a good hot spark form good points n condensor n cap n rotor n wires helps. Try running the plug gap a tad wider and especially USE A HOTTER PLUG then you been using. While running too rich is easily cured if shes burning oil youre kinda stuck. If worse comes to worse you could swap to an electronic ignition with a high energy high voltage coil and run a wide plug gap. Make sure the spark you have now is good n blue n visible as opposed to a faint thin wimpy yellow spark and if its weak check n replace the points n condensor if needed n try fresh HOTTER plugs n have good plug wires. John T
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
