Re: Farmall A fuel starvation problem
Posted by Dave in Virginia on November 06, 2005 at 12:43:47 from (24.250.112.64):
In Reply to: Farmall A fuel starvation problem posted by Dave 89 on November 05, 2005 at 15:43:03:
I have a 200 that I tried adding an inline filter to. I got the same problem until I removed the filter. The whole point of my exercise was that I wanted to get rid of rigid tubing fuel lines that seemed to leak whenever I needed to clean the glass filter remove the carb. After some searching for the correct fittings to handle a flexible fuel line, I ran into the filter problem. I added an inline gas filter because the new fittings did not have the inline metal filter at the carb fuel pipe elbow. I agree with those who say the gravity fed fuel pressure is too low to support a good flow across a modern filter. There is not much "head". I would stil like to add back that inline filter though, as my tank still contains some dirt.
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
