Re: PTO shaft angle to shartrp
Posted by mattd on November 06, 2005 at 17:04:09 from (207.91.18.48):
In Reply to: PTO shaft angle to shartrp posted by Jimer on November 06, 2005 at 16:43:29:
you could put a double u-joint on one end of the shaft. or if you cant find one that works you could put a sprocket where the shaft hooks on the snowblower and another the same size on top of the other one with a chain connecting the two and have the shaft connect to the top sprocket.
matt
Post a Followup
