Farmall Tractors Discussion Board
Re: 3-point
Posted by Harold H on December 29, 1999 at 16:33:04 from (207.244.55.190):
In Reply to: 3-point posted by Doug on December 29, 1999 at 04:41:58:
Doug,
If your 3414 had a factory backhoe, more than likely it does not have the rockshavft for a three point hitch. It also probably does not have a PTO. The easiest route for the three point hitch would be to add a aftermarket hitch using external cylinders unless your tractor does have the rockshaft in place. If you have the rockshaft the hitch from a B-275, B-414, B-424, B-444 and some other later tractors will fit. The PTO is a different story. If your tractor has a pto, good. if not, it would be very difficult to add as the pto tractors used a dual clutch and if your 3414 was not factory equipped with a pto, it does not have this or other internal parts necessary for the pto. The 3414 could be ordered from factory with backhoe, rockshaft less hitch, and pto, but we never sold one like that as all we sold and most sold everywhere with backhoes, never intended to remove the backhoe. Good luck.
Harold H
Post A Followup
: Re: Re: 3-point
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
