Re: Aces..Brake removal
Posted by TDK on November 06, 2005 at 20:28:09 from (205.188.117.73):
In Reply to: Aces..Brake removal posted by Buddy Woodson on November 06, 2005 at 17:19:44:
I haven't worked on the brakes on an MTA, so this may not apply. But if they're like the 100 series disk brakes, there should be two threaded holes in the backing plates to screw bolts into. Running the bolts in will remove the backing plate. Only thing holding plate on the hundred series tractors is a large o-ring, but they are sometimes hard to remove, as the o-ring has hardened. Behind the plate is bolts that hold the bull pinion housing to trans. To get to these bolts, backing plate must be removed.
Post a Followup
