Re: Magneto timing
Posted by Bob on April 08, 2009 at 06:49:05 from (69.178.228.68):
In Reply to: Magneto timing posted by Slappy on April 08, 2009 at 06:26:22:
You DON'T need to set the timing on a properly operating MAG while running.
Set it so it impulses AT (NOT before) TDC, and leave it there.
Earlier and you risk "kickback" while starting.
