Re: 43H pistons/sleeves/bearings
Posted by MagMan on November 08, 2005 at 02:23:08 from (205.188.117.73):
In Reply to: 43H pistons/sleeves/bearings posted by John London, Tx on November 07, 2005 at 17:20:54:
An H does not run sealing rings.There basicaly should be a overbore kit 3 and 7/16 with or with out high domes and there will be a kit for the serial #s above 390,0000 That does not concern you either. If you take a bearing shell off one of the rods they are usally stamped on the back what they are if they are 10,20 thousands under. That way you may be able to tell if its been turned already . But you will still need to do what Janicholson says to figure out if its egg shaped or not.and find a good machinist.
JON
Post a Followup
