Re: 43H pistons/sleeves/bearings
Posted by El Toro on November 08, 2005 at 04:48:10 from (205.188.117.73):
In Reply to: 43H pistons/sleeves/bearings posted by John London, Tx on November 07, 2005 at 17:20:54:
The H has pressed in sleeves, no sealing ring required. They are used on the A, B. C & Super C
because they have what is called wet sleeves and the sealing rings are use to seal the sleeves at the bottom of the block.
You need to take that crankshaft to a reputable
auto machine shop and have it measured. They can determine if it just needs polishing or needs to be ground undersize. They can also supply your
rod and main bearings that's needed. Hal
Post a Followup
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
