Re: 43H pistons/sleeves/bearings
Posted by GordoSD on November 08, 2005 at 06:11:49 from (64.68.166.234):
In Reply to: Re: 43H pistons/sleeves/bearings posted by John London, Tx on November 08, 2005 at 03:39:20:
I'd pop out the tighest fitting piston, after checking gap between it and sleeve.Might want to use ridge reamer prior to pulling them. Then remove rings and check for end gap when in the sleeve w/o the piston. If that one is out of tolerance replace all the rings. pISTONS TOO IF OUT OF TOLERANCE.
Gordo
Post a Followup
