Re: IHC 986
Posted by chadd on November 08, 2005 at 09:03:29 from (155.92.31.30):
In Reply to: IHC 986 posted by Don Anderson on November 08, 2005 at 06:28:17:
It definitely sounds like a Torque Amplifier problem to me. Since it occurs when the oil gets warm, I would guess that somewhere a seal or valve is leaking or a pump is getting weak, because as the oil gets warmer, it also gets thinner. Does your power steering work okay? Your tractor, because it is later probably has the PFC or PPH hydraulics. I will have to take a look at a manual, but I think it still has the pump in the clutch housing for the TA, steering,and brakes. If that pump is very weak, it could display the symptoms you describe.
Post a Followup
