Farmall 706 Weight
Posted by Rick MacGregor on November 09, 2005 at 07:36:54 from (204.13.147.206):
Anyone want to guess the weight of a Farmall 706? Everything in front of the seat has been removed, including the steering assembly. Bell housing/transmission is there. Narrow front end with one wheel on it. Rear tires are not loaded, no wheel weights. Flat top fenders, seat, and fast-hitch also remain, but could be removed, for what? 250 - 300 pounds?
Thanks, Rick.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
