Posted by Bob M on April 08, 2009 at 06:58:40 from (151.190.254.108):
In Reply to: Magneto timing posted by Slappy on April 08, 2009 at 06:26:22:
Slappy -
There is no "running" timing adjustment with a magneto. Like Bob says below, set the mag so the impulse trips at TDC then accept whatever advance it provides when the engine is running.
If the mag is working right timing be steady at around 35 deg BTDC from idle to max governed RPM.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
