Farmall Tractors Discussion Board
Re: IH 656 Hydro $$$$$
Posted by larry on December 30, 1999 at 06:56:51 from (208.17.195.2):
In Reply to: IH 656 Hydro $$$$$ posted by Bret on December 27, 1999 at 22:04:41:
I agree with the last guy that the engine may need overhauled soon. Most diesels of that vintage were only designed for about 5000 hrs of hard work beore overhaul. The trans is iffy, though. Are you sure that the slippage in high range isn't just because you're trying to pull too much? That trans is just like the rest of the hyd system... if you overload it, the fluid goes over a relief valve. I wouldn't worry much unless it slips under moderate loads.
Post A Followup
: Re: Re: IH 656 Hydro $$$$$
