Re: farmall cub 1948
Posted by Farmall Ed on November 13, 2005 at 05:53:05 from (65.135.143.210):
In Reply to: farmall cub 1948 posted by jim turner on November 13, 2005 at 04:55:32:
Jim , I have a 48 Cub and have had a fair share of starting problems. Some times when mine wont start I drain the carb then it will start. Have you done any thing that would change the timing? Does the tractor still have a magneto? sometimes the mag can be shorted inside making it not start.This happened on a friends Cub. I found one that the lead from the condensor was touching the inside of the dist shorting it out. Lots of things can give you starting problems and I may be wrong but it seems the Cub is more sensitive to starting problems than my H's. Hope you get it started soon. Ed
Post a Followup
