Re: 434 starting last time I hope
Posted by El Toro on November 13, 2005 at 14:50:42 from (152.163.101.13):
In Reply to: Re: 434 starting last time I hope posted by Al Sproule on November 13, 2005 at 13:50:03:
I thinks a broken wire is your problem. That terminal is hot all the time and that feeds your
ignition switch and the switch feeds voltage to the s terminal when cranking and then to your ignition. Your lights may be wire through the switch too. Let's us know if you solve your problems. Hal
Post a Followup
