Re: 544 deisel starting woes. Please help!!!!!!
Posted by K.B.-826 on November 13, 2005 at 20:04:55 from (209.163.30.73):
In Reply to: 544 deisel starting woes. Please help!!!!!! posted by dave from MN on November 13, 2005 at 17:53:59:
1- Do you understand how to operate the excess fuel control? You must have the fuel control cable held in the excess fuel position, and the throttle 1/4 open. 2- You must be using a circulating tank heater. What size (wattage) is it? 3- Have the biggest diameter cables you can get made. Check with heavy truck shops and starter/alternator shops. THEY CAN BE MADE. No matter what battery arrangement you are using, you need big cables. Forget about 24V. Get two 6V with the highest CCA you can find. Build a battery box and mount it as close to the starter as possible. The shorter the cables, the better. 4- Have the injectors rebuilt. Just trust me on that. 5- If all of this fails, the only other option is a overhaul and installing the late-style pistons. The German engines built after about 1980 start much better than the older ones. 6- Throw the damn ether can away. You've got other problems if it wouln't start with ether. I just got done overhauling a 4320 Deere which had cracked pistons from using ether. That engine was was in otherwise good shape and would not have needed anything more than a head gasket if the guy would have just kept the ether away from it. 7- Your's is a Hydro. I'm not really up on those, but your starter must also have to turn the hydro pump, as it is connected to the engine. Are you using Hy-tran? Has it been changed recently? Does pushing in the inching pedal make a difference in cranking speed?
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
