Re: Lift all stalls tractor
Posted by the tractor vet on November 14, 2005 at 06:11:42 from (4.124.78.2):
In Reply to: Lift all stalls tractor posted by Ian T on November 13, 2005 at 22:25:17:
Take out two of the washers or get a new spring and do away with the washer. You just may split the pump open . about 1250 lbs of pressure is all ya need and if that is not enough get a bigger cylinder.
Post a Followup
