Re: Farmall A head
Posted by Janicholson on November 14, 2005 at 12:18:31 from (199.17.6.175):
In Reply to: Farmall A head posted by randy on November 14, 2005 at 11:55:22:
Use a 5"xheadlength X 1/4" plate of steel
Drill holes to match rocker tower bolt holes (put tower on plate mark, drill)
Set on top of studs (with nuts on studs flush with top of stud) and use longer bolts in rocker tower holes (thread in at least 3 bolt diameters) till they are evenly tight on plate.
Use head nuts to jack the head up in the air.
If everything is disconnected, this breaks the seal and not the casting.
JimN
Post a Followup
