Re: Super Brakes
Posted by Daniel H. on November 15, 2005 at 08:33:32 from (66.226.33.19):
In Reply to: Super Brakes posted by scotty on November 15, 2005 at 06:27:06:
I think you'll be fine with the band. Didn't the glass bead leave the drums rough? I usually have mine turned on a brake lathe. They can turn outside drums if they set it up right. Usually the biggest right brake problem is a worn out pedal bracket; the pedal flops around instead of pulling the break band.
Post a Followup
