Ian T hyd From yesterday
Posted by Janicholson on November 15, 2005 at 16:15:11 from (66.173.50.157):
Dear Ian The unit should return to hold when topped out. Either the lever is binding inside, you mistook the pressure sensitive return control for the overall pressure limit valve, or the unit is sticking. most likely it will need to be gone through with a manual. Putting washers under the spring is similar to pennies in a fuse box. It works till something else blows.
JimN
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
