Re: 544DEISEL STARTING WOES AGAIN
Posted by K.B.-826 on November 15, 2005 at 16:20:03 from (24.180.146.111):
In Reply to: 544DEISEL STARTING WOES AGAIN posted by dave from MN on November 15, 2005 at 04:34:35:
Dave, I think the tractor vet is thinking of the British utilities with that engine when he says the fuel control should be halfway between run and stop. It sounds like you've got it right to me. To check, start the engine and run it about 1/4 throttle. Pull the cable back to where you hold it when you start it. The engine will slow down and start to kill until you hit the start-up position, at which point it will wind up to about 1900 RPM.
I would get the biggest cables you can. Build a battery box to hold two 6-volts with the highest CCA you can get and move the batteries close to the starter.
Throttle position makes a huge difference when starting. Set it to 1/4 throttle.
What size tank heater do you have?
Post a Followup
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
