Re: antonholstrom@msn.com
Posted by captaink on November 16, 2005 at 06:33:26 from (66.115.214.56):
In Reply to: antonholstrom@msn.com posted by Anton C Holstrom on November 16, 2005 at 05:43:45:
You definitely have a fuel starvation problem. Others have given you good places to look for the cause. It could be a restriction in the tank, fuel line, sediment bowl under the tank, or a fuel filter if there is one. Could be manifold gasket leak, you can check by spraying carb cleaner around the manifold. If the engine picks up rpm you found a leak. Basically, think it through and keep checking until you find the cause.
Post a Followup
