Re: 6 volt battery hookup
Posted by captaink on November 16, 2005 at 08:29:53 from (66.115.214.56):
In Reply to: 6 volt battery hookup posted by brian 37 on November 16, 2005 at 08:18:06:
The H originally was 6-Volt Positive Ground; however it may have been changed during its life. The smoking is coming from a loose battery connection, a heavy load, (possibly the starter has the drive jammed into the flywheel ring gear preventing the starter from turning) or it could also be a starter that has a shorted out armature or field windings. If it is only smoking when you try to run the starter, the starter and related wirings are the place to start. One thing you need to do thought is polarize the generator to make sure that it is set up for positive ground and check to make sure that the – terminal on the coil (only if you have a distributor) is connected to the switch. The ammeter may read backwards (shows a charge when you turn on the lights with the engine off) if the polarity is not right, but nothing else on a stock H will be affected if the ground was changed from positive to negative.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
