Re: 6 volt battery hookup
Posted by John T on November 16, 2005 at 10:56:29 from (66.244.90.98):
In Reply to: 6 volt battery hookup posted by brian 37 on November 16, 2005 at 08:18:06:
Brian, I pretty much agree with the captains good advice. The starter will still turn the same direction n work REGARDLESS if it were hooked Positive OR Negative ground. I think the first thing I would do is remove, clean n wire brush, then re attach that smoking connection cuz it may be loose or burned or corroded. To be safe, you may as well remove, clean n wire brush, then reattach each n every battery n starter n ground cable (and where the ground cable attaches to the tractor frame) while youre at it.
Im thinkin its EITHER a bad connection or the starter itslef may be bad or else its mechanically stuck/jammed. Once you fix the loose connection, see if when you try n crank her the lights would dim badly or the batterys voltage drops drastically, in which case I suspect a bad or a stuck/jammed starter. Loosen it n retighten and/or crank the engine somehow to see if it will free up??? Mabe the starter drives jammed into the flywheel teeth??
If when trying to crank theres no smoke or sizzle and the battery voltage dont drop much and/or lights dont dim much, then I suspect the starter switch may be bad or the starter where it connects to the switch.
You may wanna also check where the ground cable attaches to the tractor for a loose or burned connection and any connection on the switch n starter???
John T
Post a Followup
