Re: charging system modification
Posted by John T on November 17, 2005 at 14:54:27 from (66.244.90.98):
In Reply to: charging system modification posted by Joe Lauricella on November 17, 2005 at 13:33:41:
Joe, to add just a bit to Bob's advice, if its not already, the main output wire from the Alternators big rear output stud I replace with 10 gauge. I like to see at least 10 ohms of resistance in the Alternators lil No. 1 side excitation terminal as current limiting protection, however, the idiot light can serve that purpose well provided you use it to excite the alternator as Bob noted. This is for the GM 10SI 3 wire Negative ground Alternator system, they are inexpensive and readily available is why they get used so often.
John T
Post a Followup
