Re: 1941 M Electrical Problem - Bob M I need your
Posted by Bob M on November 18, 2005 at 05:40:28 from (151.190.254.106):
In Reply to: 1941 M Electrical Problem - Bob M I need your HELP posted by BIG JOHN on November 17, 2005 at 13:49:16:
Big John - A couple possibilities:
1 – You have an internally ballasted (so-called “12 volt”) coil. When combined with the series ballast resistor it causes the voltage to drop so low at the coil while cranking that it won’t fire. SOLUTION: Eliminate the ballast resistor!
2 – If your M has been retrofitted with a starter solenoid, the feed to the coil is wired wrong. Punch below for the correct wiring. (This incidentally also shows the proper + and – coil connections….):
Good luck and post back what you find!!
Post a Followup
