Re: 786 vs. 886
Posted by Mike in Vt on November 18, 2005 at 06:51:53 from (159.105.233.141):
In Reply to: 786 vs. 886 posted by Mike in Vt on November 18, 2005 at 05:59:21:
There are many more 986's and 966's in the area but they are usually up in the 8000hr range which I'm a little reluctant to consider. Both the 786 and the 886 have a cab and are in good condition. I was told that the 886 and the 786 were contemporary but that the 786 was a later tractor. Outside of parts is the engine in the 786 worse that than 986? How do I tell if it is a late or early one?
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
