Re: farmall 140 grills
Posted by Hugh MacKay on November 18, 2005 at 14:23:40 from (209.226.106.191):
In Reply to: farmall 140 grills posted by clarence christman on November 18, 2005 at 10:54:13:
clarence: Both are correct for specific years. Someone must have changed the grill in your tractor. Starting in 1958 the grill bars ran horizontal. With the introduction of 04-06 tractors early in 1963 the 140 grill was changed to vertical bar lines matching the larger tractors. Even when the big tractors changed again in 67-68 the 140 retained the vertical 04-06 grill.
I really wouldn't bother to make your tractor correct if I were you. I never had a 140 with the horizontal bar grill, however on the larger tractors such as 460-560 the grill never would stay tight. Always had a rattle or vibration, or worse still falling off and you would run over it, then after that it just got worse.
Post a Followup
